Zabbix Performance (history syncer 100%)
  • Timwetech
    • May 2019
    Since November 2018 we have performance problems with Zabbix 3.4.10.
    Since this time, we made tuning for tcp connections, tuning in the OS (CentOS 6.9), tuning in the MariaDB conf, tuning in the Zabbix Server conf and tuning in the Zabbix Proxies conf.
    The following problem remains:
    2 times a day (5:22 p.m. and 8:22 p.m., we have different hours in the past) History Syncer reaches 100% and proxies become "NoDataProcessing".
    While history syncer is at 100% several "NoData" alarms start to appear.
    To recover, we stop the 2 major proxies, restart the server and raise the 2 proxies with a time interval.
    Number of hosts 6679
    Number of items 732813
    Number of triggers 358638
    Required server performance, new values per second 2695.54
    Hardwares (VM):
    - Server:
    CPU: 4 CPU
    Memory: 24GB
    - Database (Ver 15.1 Distrib 10.3.4-MariaDB, for Linux (x86_64) using readline 5.1):
    CPU: 8 CPUs
    Memory: 64GB
    Disk: SSD
    Infrastructure:
    1 Zabbix Server version 3.4.10 (lx-all-mon-zserver-01)
    1 Database Ver 15.1 Distrib 10.3.4-MariaDB (lx-all-mon-zdb-03)
    6 proxies for machines
    1 proxy for Databases monitoring
    1 proxy for webchecks
    Server, proxies and database configurations.
    Server and database graphics
  • Timwetech
    • May 2019
    Solution:
    - My.cnf has been changed to the settings below:
    # This group is read both both by the client and the server
    # use it for options that affect everything
    [client-server]
    # include all files from the config directory
    [mysqld]
    datadir = /opt/timwe/data/mysql
    innodb_log_group_home_dir = /opt/timwe/data/mysql/innodblog
    log-bin = /opt/timwe/data/mysql/binlog
    log_error = /opt/timwe/log/mysql_error.log
    slow_query_log_file = /opt/timwe/log/slow_query.log
    tmpdir=/opt/timwe/data/mysql/tmpfs
    innodb_autoextend_increment = 256
    innodb_buffer_pool_instances = 12
    innodb_buffer_pool_size = 48G
    innodb_concurrency_tickets = 5000
    #innodb_data_file_path = ibdata1:1G:autoextend
    #innodb_file_format = Barracuda # default
    innodb_file_per_table = 1
    innodb_flush_log_at_trx_commit = 2
    innodb_flush_method = O_DIRECT
    innodb_log_file_size = 512M
    innodb_log_files_in_group = 8
    innodb_old_blocks_time = 1000
    innodb_open_files = 2048
    innodb_stats_on_metadata = OFF
    #innodb_autoinc_lock_mode = 2
    innodb_force_recovery = 0
    #innodb_io_capacity = 3000
    #large-pages
    skip-name-resolve
    bind-address = 0.0.0.0
    default_storage_engine = innodb
    event_scheduler = ON
    binlog-row-event-max-size = 8192
    binlog-format = MIXED
    character_set_server = utf8
    collation_server = utf8_bin
    expire_logs_days = 1
    join_buffer_size = 262144
    max_allowed_packet = 32M
    max_connect_errors = 10000
    max_connections = 5000
    max_heap_table_size = 134217728
    port = 3306
    query_cache_type = 1
    query_cache_size = 268435456
    slow-query-log = ON
    table_open_cache = 2048
    thread_cache_size = 512
    tmp_table_size = 134217728
    user = mysql
    wait_timeout = 86400
    #key_buffer_size = 10G --unset
    #log-bin = mondb1-bin
    #sync_binlog = 0
    #optimizer_switch='index_condition_pushdown = off';
    [mysql_safe]
    log-error=/opt/timwe/log/mysqld_safe_error.log
    pid-file=/var/run/mysqld/mysqld.pid
