fping from zabbix agent - permission denied
  • vish2398
    • Jun 2020
    I know there are several topics about fping, but I've read through them all and I am still having trouble getting something that should be pretty simple working.
    I am trying to do a simple ping test from a host (that's running zabbix agent) to an external host.
    In my zabbix_agentd.conf file I have setup a UserParameter such as:
    UserParameter=vpnPing[*],fping $1 |grep -c alive
    My fping permissions are as such:
    # ls -l /sbin/fping
    -rwsr-sr-x. 1 root zabbix 52904 Aug 5 2019 /sbin/fping
    If I run the zabbix_agentd test I get (fake ip listed for example purposes)
    # zabbix_agentd -t vpnPing[123.456.78.901]
    vpnPing[123.456.78.901] [t|1]
    So that seems to work.
    When I go to the zabbix UI and look at the latest data I see:
    2020-06-04 17:55:30 sh: /usr/sbin/fping: Permission denied
    0
    The interesting this is the 0 at the bottom. I've also seen it be 1 at times. That sounds like something is working, but I don't get why I get the permission denied.
    Also when I look at the audit log I see:
    type=AVC msg=audit(1591307793.058:12551): avc: denied { execute } for pid=30242 comm="sh" name="fping" dev="nvme0n1p2" ino=8410299 scontext=system_u:system_r:zabbix_agent_t:s0 tcontext=system_ubject_ring_exec_t:s0 tclass=file permissive=0
    type=SYSCALL msg=audit(1591307793.058:12551): arch=c000003e syscall=21 success=no exit=-13 a0=55c20f61e450 a1=1 a2=7ffc91d9bb10 a3=0 items=0 ppid=30241 pid=30242 auid=4294967295 uid=990 gid=988 euid=990 suid=990 fsuid=990 egid=988 sgid=988 fsgid=988 tty=(none) ses=4294967295 comm="sh" exe="/usr/bin/bash" subj=system_u:system_r:zabbix_agent_t:s0 key=(null)^]ARCH=x86_64 SYSCALL=access AUID="unset" UID="zabbix" GID="zabbix" EUID="zabbix" SUID="zabbix" FSUID="zabbix" EGID="zabbix" SGID="zabbix" FSGID="zabbix"
    type=PROCTITLE msg=audit(1591307793.058:12551):
    I'm running RHEL 8.2.
    # zabbix_agentd -V
    zabbix_agentd (daemon) (Zabbix) 4.4.9
    $ zabbix_server -V
    zabbix_server (Zabbix) 4.4.9
    # fping -v
    fping: Version 3.16
    I have the Item in Zabbix configured as Type: Zabbix agent
    If I try: zabbix_get -s [my_zabbix_server_ip] -k vpnPing[123.456.78.901]
    it does timeout (not sure why): zabbix_get [30549]: Timeout while executing operation
    But not sure that last part with zabbix_get is relevant b/c the checks to seem to be getting back to the zabbix server but it just says permission denied.
    I've been struggling with this for a while now and hoping someone can help me out?
  • tim.mooney
    • Dec 2012
    • 1435
    You don't need the group set-id bit to zabbix on /usr/sbin/fping, that's pointless.
    The problem is that SELinux is blocking the 'zabbix' user from executing a shell and running that command. If you're going to have SELinux enabled on the client, you'll need to adjust the labels so that the zabbix user can run this setuid root executable.
