PHP upgrade for zabbix 5.0
  • markfree
    • Apr 2019
    • 875
    I'm looking to update a Zabbix 4.4 to a Zabbix 5.0 with a CentOS 7, so...
    I was trying out PHP7 upgrade guide at Zabbix documentation and got stuck at some point.
    The doc says to enable PHP 7.2 dependencies by installing PHP packages from Red Hat Software Collections:
    # yum install centos-release-scl
    Package centos-release-scl-2-3.el7.centos.noarch already installed and latest version
    Nothing to do
    I did that, but it was installed already.
    Then I followed to list the new php7 packages, but it could not find any.
    # yum list rh-php7\*
    Error: No matching Packages to list
    Any idea how to update that PHP?
  • Atsushi
    • Aug 2013
    • 2028
    Make sure the settings in the centos-sclo-rh section in /etc/yum.repos.d/CentOS-SCLo-scl-rh.repo are enabled.
    [centos-sclo-rh]
    name=CentOS-7 - SCLo rh
    #baseurl=http://mirror.centos.org/centos/7/sclo/$basearch/rh/
    mirrorlist=http://mirrorlist.centos.org?arch=$basearch&release=7&rep o=sclo-rh
    gpgcheck=1
    enabled=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-SIG-SCLo
