Cant use domain name in zabbix_proxy.conf, work properly with ip of k8s cluster node
  • joao.medeiros
    • Feb 2022
    Hi friends,
    I'm trying to implement Zabbix Server in Kubernetes, but I'm facing some difficulty with network communication between Zabbix Proxy and Zabbix-Server. Take a look at my scenario:
    Click image for larger version  Name:	zabbix-scenario.png Views:	0 Size:	34.9 KB ID:	440411
    zabbix.domain.com => 10.10.10.110 (HAPROXY)
    Configuring my zabbix_proxy.conf file, when I insert the ip address of the worker-1 node where are the zabbix pods in some moment, the communication works fine. But when I try to insert my domain as a value, doesn't.
    Look the logs of Zabbix Proxy when I put zabbix.domain.com as Server value.
    root@zabbix-proxy-02:/etc/zabbix# tail -f /var/log/zabbix/zabbix_proxy.log
    1051486:20220223:225627.200 proxy #95 started [icmp pinger #5]
    1051487:20220223:225627.201 proxy #96 started [icmp pinger #6]
    1051488:20220223:225627.201 proxy #97 started [icmp pinger #7]
    1051489:20220223:225627.202 proxy #98 started [icmp pinger #8]
    1051490:20220223:225627.203 proxy #99 started [icmp pinger #9]
    1051491:20220223:225627.203 proxy #100 started [icmp pinger #10]
    1051492:20220223:225627.204 proxy #101 started [history poller #1]
    1051493:20220223:225627.204 proxy #102 started [availability manager #1]
    1051375:20220223:225627.235 cannot send heartbeat message to server at "zabbix.domain.com": connection is not allowed
    1051376:20220223:225628.129 cannot send proxy data to server at "zabbix.domain.com": connection is not allowed
    1051376:20220223:225629.152 cannot send proxy data to server at "zabbix.domain.com": connection is not allowed
    1051376:20220223:225630.171 cannot send proxy data to server at "zabbix.domain.com": connection is not allowed
    My haproxy.conf configuration.
    frontend http
    mode tcp
    bind *:80
    default_backend http_back
    frontend https
    mode tcp
    bind *:443
    default_backend https_back
    frontend zabix
    mode tcp
    bind *:10051
    default_backend zabbix_back
    frontend kubernetes
    mode tcp
    bind *:6443
    option tcplog
    default_backend kubernetes-master-nodes
    mode tcp
    balance roundrobin
    option tcp-check
    server master-0 10.10.10.111:6443 check fall 3 rise 2
    backend http_back
    mode tcp
    option log-health-checks
    default-server inter 10s fall 2
    server worker-0 10.10.10.112:80 send-proxy check
    server worker-1 10.10.10.113:80 send-proxy check
    server worker-2 10.10.10.114:80 send-proxy check
    backend https_back
    mode tcp
    option tcp-check
    server worker-0 10.10.10.112:443 send-proxy check
    server worker-1 10.10.10.113:443 send-proxy check
    server worker-2 10.10.10.114:443 send-proxy check
    backend zabbix_back
    mode tcp
    option tcp-check
    server worker-0 10.10.10.112:10051 send-proxy check
    server worker-1 10.10.10.113:10051 send-proxy check
    server worker-2 10.10.10.114:10051 send-proxy check
    Can someone help? Or have any idea?
