Mariadb version issue after zabbix upgrade
  • t.heroult
    • Jun 2021
    Hi all
    After last upgrade, the ticket ZBXNEXT-7813 explains that mariadb higher than 10.7 is fordbiden, but it's too late, my mariadb is allready 10.8.
    My zabbix server is a Debian 10 - buster.
    What can I do ?
    I don't know (and can't find) how to downgrade the mariadb suite...
    Somebody has a how-to for that ?
    Regards
    Tom
  • Answer selected by Markku at 04-07-2022, 14:27.
    Markku
    • Sep 2018
    • 1784
    If we assume that using MariaDB 10.8 is technically fine, have you already tried setting AllowUnsupportedDBVersions? https://www.zabbix.com/documentation...w600#databases
    Otherwise, regarding the database downgrade, you could try dumping the database and them importing it to another server running older MariaDB version. I have no experience about downgrading the database engine, I would assume that is not possible.
    Markku
    • Markku
      • Sep 2018
      • 1784
      Markku
      • t.heroult
        • Jun 2021
        OK, thanx, I will try the settings and let you know
        Tom
        • t.heroult
          • Jun 2021
          Great, it worked !
          Thanx Markku !
