Cisco Interface Data Missing after upgrade to 6.0.15
  • PatrickR-STI
    • Jun 2020
    • 12
    After upgrading to 6.0.15, our Cisco interface stats are No Data.
    If we remove the Change per Second preprocessing, data begins to flow but the multiplier seems off as we are now showing a much larger amount of data being reported than what should be.
    Any assistance would be appreciated.
  • Thac01
    • Apr 2023
    Same problem... no pull data from Cisco Interfaces (only number/float example bit rate) and from a lot of other hosts
    • john275
      • Apr 2023
      I have done a fresh install of 6.0.15, added a couple of Cisco devices and they are showing [no data] for interfaces, if I do a [test] data returns OK
      • Spoonman
        • Aug 2013
        • 45
        I have a similar problem with missing (blank) interface data, from a Synology NAS.....
        Problem started with update 6.0.14 > 6.0.15
        Zabbix server runs on AlmaLinux 8.7
        • PatrickR-STI
          • Jun 2020
          • 12
          I installed a fresh copy of 6.0.15 and found that ALL network interfaces showed no data. I was only able to resolve the issue by upgrading to 6.2.
            • 5004
            • Spoonman
              • Aug 2013
              • 45
              Hm, I prefer to stick to the LTS version (6.0.x).
              Thanks for your reaction!
              • PatrickR-STI
                • Jun 2020
                • 12
                While I would normally agree, we needed to have our monitoring up before the weekend and this was the only solution that seemed to work.
                • Spoonman
                  • Aug 2013
                  • 45
                  There is a downgrade option, back to 6.0.14:
                  • PatrickR-STI
                    • Jun 2020
                    • 12
                    Thank you for the link.
                    • Spoonman
                      • Aug 2013
                      • 45
                      Not sure if you can downgrade from a rolling 6.2 version to a 6.0.x LTS version......
                      (you upgraded from 6.0.15 to 6.2).
                      • PatrickR-STI
                        • Jun 2020
                        • 12
                        Upgrading to 6.2 was always on the roadmap with 6.4 coming out. Just had to do it sooner than we would have liked.
