How to monitor Apache Tomcat with Zabbix Java Gateway installed on the Zabbix server
  • studero
    • Aug 2023
    • 85
    Hi all,
    I want to monitor the Apache Tomcat server with the template Apache Tomcat by JMX. But I'm not sure if my configuration about hte Zabbix Java Gateway installed into the Zabbix server is correct.
    How can verified it ? And how can use it to monitor Apache Tomcat server ?
    Thanks for your help
    Best regards
    Olivier​
  • tim.mooney
    • Dec 2012
    • 1436
    The Zabbix Java Gateway works as a kind of a "proxy". It needs to run somewhere, and for smaller environments having it installed and running on the same server as the Zabbix server makes sense.
    With that background in mind, have you read the section of the documentation on JMX monitoring? https://www.zabbix.com/documentation...jmx_monitoring
    There's a link near the start of that documentation that talks about setting up the Zabbix Java gateway: https://www.zabbix.com/documentation.../concepts/java
    Does that help?
    • studero
      studero commented
      Hi Tim,
      Thanks for your help, I need to disable SELinux to have a working solution.
      Regards
      Olivier
