Using java in zabbix 6.0
  • Danio9004
    • Sep 2023
    • 13
    We have zabbix version 6 installed. And on the same CI we have a java version installed that we need to update. A question for specialists: in such a situation, is it enough to just upgrade Java, or do you need to upload a whole package with the client, or something like that?
    Does java upgrade have no effect on zabbix at all?
    Can anyone help?​
    • 5004
    Java is not required for Zabbix to work. Only for java GW, but that is only, if it is installed at all..
