Zabbix 6.4: Top hosts by CPU utilization e Windows
  • andreagx
    • Oct 2021
    • 29
    The "Top hosts by CPU utilization" shows "No data found" even in settings/host I added multilple Windows hosts.
    With Linux hosts works but not if I have Windows hosts
    What should I do to get this widget work?
    Thank you
  • Answer selected by andreagx at 17-02-2024, 14:45.
    andreagx
    • Oct 2021
    • 29
    Solved.
    Seems Linux and Windows hosts can't stay in the same Widget
    • andreagx
      • Oct 2021
      • 29
      Solved.
