Hi! I have a problem with an agent and a zabbix proxy conection. I have already check the hostname in the conf file, I have check if there is conection through 10050 and 10051 ports by telnet, I have check the hostname file to see if it is the same name when executing hostname command, I have changed the Server and ServerActive in the conf file to the IP and DNS multiple times, I have tried to type the name of the host in hostname parameter instead of using HostnameItem=system.hostname, the hostname is the same in zabbix frontend and the template selected is Linux by zabbix agent but logs remains the same:
138929:20240304:183919.369 Starting Zabbix Agent []. Zabbix 6.4.12 (revision dba2d5bd63b).
138929:20240304:183919.372 **** Enabled features ****
138929:20240304:183919.374 IPv6 support: YES
138929:20240304:183919.377 TLS support: YES
138929:20240304:183919.379 **************************
138929:20240304:183919.382 using configuration file: /etc/zabbix/zabbix_agentd.conf
138929:20240304:183919.384 agent #0 started [main process]
138930:20240304:183919.387 agent #1 started [collector]
138931:20240304:183919.389 agent #2 started[listener #1]
138932:20240304:183919.392 agent #3 started[listener #2]
138933:20240304:183919.395 agent #4 started[listener #3]
138934:20240304:183919.398 agent #5 started [active checks #1]
138934:20240304:183919.404 no active checks on server [:10051]: host [] not found
I do not have any idea of what could be happening if I have already check all about ports and hostname.
Could you help me please?
