Problems executing scripts on Windows machines in Zabbix 7.0
  • JorgeSach
    • Jul 2022
    I have problems running manual and automatic scripts on my Windows machines after upgrading my zabbix server to version 7.0
    The problem I'm running into now is the following when I run a script on one of my machines:
    Click image for larger version  Name:	image.png Views:	0 Size:	14.9 KB ID:	486045
    However if I run the same command in my server console to a powershell script:
    Click image for larger version  Name:	image.png Views:	0 Size:	11.8 KB ID:	486046
    ​Even the command without calling the script:
    Click image for larger version  Name:	image.png Views:	0 Size:	13.0 KB ID:	486047​
    There is communication between server and agent. Checked in both directions, also the execution timeout is 30 seconds on server and agent.
    I have installed version 7 of the agent on my Windows machine, it doesn't work either, I have returned to 6.4 and it doesn't work either. I don't know if it's some problem in the GUI or some new parameter that I missed. In the administration part of my frontend I have configured the UI script timeout to 60 seconds. However, no test that I have carried out or tested has given results.
    In my agent log I don't see anything strange regarding these errors.
    I also have items configured with PowerShell commands to check other configurations in my Windows and they work perfectly.
    The problem is that the scripts that I have to launch by hand cannot be implemented as items because I use them to perform specific tasks or when one of my triggers fires.​
    A hand with this?
    It will be appreciated
    Greetings​​
  • Giam
    • Jul 2025
    Hi there,
    Hopefully you already fixed your issue... but for others that have the same problem after doing Zabbix Server upgrade.... and suddenly no script were working.
    Just found out in my /etc/zabbix/zabbix_server.conf:
    EnableGlobalScripts=0
    It seems to have been added during upgrade from 6.0 to 7.0.
    Removed that line, restart zabbix_server and voilà.
    Based on what I can see in the docs, it seems to be on purpose for new installs: https://www.zabbix.com/documentation...eGlobalScripts
    • jh_zeus
      • Aug 2025
      Hi there,
      I have the same issue.
      I have many servers and two of them are responding a simple ipconfig command (["C:\Windows\System32\cmd.exe /c ipconfig"]) in a second and the other ones lead to a timeout.
      however not evertime. When you try it 4 oder 5 times, there is a chance that the Zabbix Manual Script succeeds an reponds with the ipconfig output from the machine.
      I'vetreif to run it with the command
      zabbix_get -s <IP> --tls-psk-identity="<XX>" --tls-psk-file=/etc/zabbix/...." -k 'system.run["C:\Windows\System32\cmd.exe /c ipconfig"]'
      and that works fine buz when I try to trun it from the UI it says "timeout". But like I said 3 times from 4.
      The Solution with
      did not work. I would be happy if somebody could help me
