SNMP not resolving - Fresh install Zabbix 7.2 on Ubuntu 24.04
  • jdupree
    • Feb 2025
    Running snmpwalk -v 1 -c "string" "Switch IP" and getting Timeout: No Response from X.X.X.X.
    Fresh install Zabbix 7.2 on Ubuntu 24.04. Verified SNMP is installed on the server. Only info I am finding is a few blogs stating "To be able to retrieve data provided by SNMP agents on these devices, Zabbix server must be initially configured with SNMP support by specifying the --with-net-snmp flag." Trying to verify that and or configure that to be enabled and setup and haven't found a definitive source on how. I don't remember seeing this tag on the install script.
    • 5008
    If you installed from official packages, then you have it enabled. "--with-net-snmp" comes to play, if you compile by yourself.
    If your snmpwalk already gets timeout, then it has nothing to do with Zabbix server... check your fw-s etc. Check that your switch even cares to answer to v1 queries... Maybe it is configured for v2c or even v3...
    Check your local selinux errors also.
