Randomly proxy stops collecting data from SNMPv3 hosts
  • asindona65
    • Mar 2024
    Hi guys
    I'm experiencing the following problem. I have a Zabbix 7.0.10 instance configured with several proxies, one for each customer (7.0.8 and 7.0.9 version for proxies, 7.0.9 for the proxy where there is the issue). Recently I started to monitor new hosts with SNMPv3 and after configuration everything works. Randomly I see that the local proxy stops collecting data from SNMPv3 hosts but everything else is collected.
    snmpwalk for those hosts is perfectly working with, of course, the same settings.
    If I restart the proxy everything works again, so it is neither a configuration problem nor an host problem, just localized on the proxy.
    I tried to increase the SNMP collectors, though it shouldn't be correlated but the problems randmly appear.
    Any ideas?
    P.S. Here is a piece of log when the error happens. It SEEMS a network error BUT the proxy isn't able to restart monitoring on an SNMPv3 host until I restart the proxy itself. No problem with SNMPv2
    87929:20250619:003849.989 SNMP agent item "net.if.duplex[dot3StatsDuplexStatus.24]" on host "PA-UF-SW-01" failed: first network error, wait for 15 seconds
    87939:20250619:003856.549 resuming SNMP agent checks on host "PA-UF-SW-03": connection restored
    87940:20250619:003904.581 resuming SNMP agent checks on host "PA-UF-SW-01": connection restored
    87929:20250619:004018.102 SNMP agent item "net.if.speed[ifSpeed.55]" on host "PA-UF-SW-03" failed: first network error, wait for 15 seconds
    87941:20250619:004033.713 resuming SNMP agent checks on host "PA-UF-SW-03": connection restored
    87938:20250619:004434.155 SNMP agent item "system.net.uptime[sysUpTime.0]" on host "PA-UF-SW-03" failed: first network error, wait for 15 seconds
    87941:20250619:004449.971 resuming SNMP agent checks on host "PA-UF-SW-03": connection restored
