convert SNMP ifInOctets in "ifin-kBit"
  • 753713
    • Apr 2006
    • 137
    i have the same problem as in that Thread http://www.zabbix.com/forum/showthread.php?t=5284.
    We can not convert SNMP ifInOctets / ifOutOctets in "ifin-kBit" / "ifOut-kBit"?
    Does anybody know a formula to calculate this?
    Ideas?
    Christian
    ______________________________
    Version : 2.0.x
    Server OS: Ubuntu 12.04
    Zabbix Servers: 12
    Monitored Windows Server: ~ 1000
  • 753713
    • Apr 2006
    • 137
    i found this by CISCO:
    http://www.cisco.com/en/US/products/...0803a867d.html
    Input utilization =(delta(ifInOctets) x 8 x 100) : ((number of seconds in delta) x ifSpeed)
    Output utilization = (delta(ifOutOctets) x 8 x 100) : ((number of seconds in delta) x ifSpeed)
    as I can realize this formula in zabbix??
    Christian
    Version : 2.0.x
    Zabbix Servers: 12
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Use multiplier in item definition. Why divide by ifSpeed? I don't get it.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • 753713
        • Apr 2006
        • 137
        is this configuration OK??
        [IMG]zabbix.jpg[/IMG]
        thanks,
        Christian
        Version : 2.0.x
        Zabbix Servers: 12
        • swaterhouse
          • Apr 2006
          • 268
          That config should work.
          By dividing by ifSpeed you get % utilization instead of bytes transferred.
          I would rather have zabbix do what it does (store bytes per second) and set a maximum on the graph so you can just visually see the percentage used.
          Scott
