Another way to monitor Oracle
  • 483
    • Jul 2011
    • 9
    #76
    when i use
    "UserParameter=pool_free_memery,/etc/zabbix/externalscripts/check_ora/check_ora_sendtrap.sh -i orcl -q pool_free_mem
    UserParameter=waitsqlnet,/etc/zabbix/externalscripts/check_ora/check_ora_sendtrap.sh -i orcl -q waits_sqlnet"
    write it in the zabbix_agentd.conf.
    I can get a number use ,"/etc/zabbix/externalscripts/check_ora/check_ora_sendtrap.sh -i orcl -q waits_sqlnet"
    in the terminal it has the answer.but when i use "pool_free_memery","waitsqlnet"as the key of the agent.but i can't get a Item key to monitor in the zabbix web.(I create oracle user .I only can open the oracle using oracle user.I can't open it with the root or zabbix user.how can i chanslate it .and every user can open the oracle).
    can you help me?
    • dalle
      • Mar 2009
      • 402
      #77
      If you have everything configure on "oracle" user you should be able to use zabbix_send under "oracle" user, try to check if path is correct (inside the script) and if you can use-it.
      Your issue seem caused by this kind of error.
      let me know
      btw It's holyday here so on next week I will not reply
      Andrea Dalle Vacche
      website:http://www.smartmarmot.com/
      e-mail:
      Author of:Mastering Zabbix Book - second edition
      Zabbix Network Monitoring Essentials
      • 483
        • Jul 2011
        • 9
        #78
        let me know
        "try to check if path is correct (inside the script) and if you can use-it."
        what doed this mean?vi zabbix_send or change the zabbix_send to be root user?
        • dalle
          • Mar 2009
          • 402
          #79
          try to call zabbix_send inside your oracle user and see if enviroment's variable are right and everything work
          Try to see if you can call zabbix_send try to see if the specified path inside the scripts is right...
          just unix's admin stuff
          Andrea Dalle Vacche
          e-mail:
          • bllack
            • Apr 2013
            How can i fix this problem?
            PHP Code:
            root@zab /e/z/externalscripts# ./check_ora.sh -i dbname
            ./check_ora.sh: 108: ./check_ora.sh: Bad substitution
            root
            @zab /e/z/externalscripts# ./check_ora.sh -i dbname -s
            in log at that moment:
            PHP Code:
             WARN  Orabbix - Error while executing ->pool_misc- on database ->dbname- Exception received ORA-00942: table or view does not exist
             WARN  Orabbix
            - Error while executing ->pool_sql_area- on database ->dbname- Exception received ORA-00942: table or view does not exist
            but that tables are exist:
            PHP Code:
            SQL> SELECT TO_CHAR(ROUND(SUM(decode(pool,'shared pool',decode(name,'library cache',0,'dictionary cache',0,'free memory',0,'sql area',
            0,(bytes)/(1024*1024)),0)),2)) pool_misc
            FROM V$SGASTAT
            ;  2    3
            POOL_MISC
            1302,62
            PHP Code:
            SQL> SELECT    TO_CHAR(ROUND(SUM(decode(pool,'shared pool',decode(name,'sql area',(bytes)/(1024*1024),0),0)),2)) pool_sql_area
            FROM V$SGASTAT
            ;  2
            POOL_SQL_AREA
            0
            • mfric
              • Nov 2012
              #81
              Orabbix - disabled items
              Hello, I'd like to ask if orabbix is querying also for disabled items in zabbix when they are queryies in query.props for this item.
              Thanks.
