Is there a quicker way to update Item Interval's?
  • greavette
    • Jul 2015
    • 82
    Hello Forum,
    I want to increase the update interval for items in a template. I would full clone the template to make a new one. On the new template is there a quicker way to update the Item Interval or do I have to go into each item and change the interval?
    Thank you.
  • Answer selected by greavette at 22-11-2022, 17:21.
    jtnfoley
    • Mar 2022
    • 80
    Edit your clone, go to Items, select each item by check box then do Mass Update. The update interval can be updated there (see screengrab below.)
    Also, change the interval in Item Prototypes and all the discovered items will reflect the new prototype interval.
    • tim.mooney
      • Dec 2012
      • 1435
      You could probably export the old template to one of the export formats (XML, YAML, or whatever) and then use regexes or search-and-replace in an editor to modify the appropriate field. Once you have the template fixed up, import it under a new name.
      • greavette
        • Jul 2015
        • 82
        Hello tim.mooney and thank you for this reply.
        I had thought of doing this. But, for example, I exported the template 'Windows by Zabbix agent' to a YAML file. I searched the file for the interval or for 1m (as an interval) and I couldn't find where in the YAML file the interval or each item is set? Where in the YAML file do I find the interval for each item so I can change it and import the template back into my Zabbix (under a different name).
        thank you.
        • jtnfoley
          • Mar 2022
          • 80
          • greavette
            • Jul 2015
            • 82
            jtnfoley, Wow! That was what I was looking for! Thanks very much for showing me how to quickly and easily update the interval on my cloned templates.
