SNMP Builder for Zabbix
  • FTaras
    • Aug 2014
    Originally posted by snake79
    I made this zip file that contains snmpbuilder patched file for Zabbix 2.2.5.
    Unzipping this file into your "www-root" directory (/usr/share/zabbix for me), enables INSTANTLY access to SNMP Builder functions.
    You have to overwrite files when requested
    Tested with CentOS 6.5 64 bit. Only for zabbix 2.2.5, I cannot guarantee for other versions
    Any feedback will be appreciated.
    Best regards
    Ubuntu Server/zabbix 2.2.5 & zabbix VAppliance 2.2.2 on bouth
    Fatal error: Call to a member function useJQueryStyle() on a non-object in /var/www/html/include/html.inc.php on line 539
    Could you post all your frontend folder? thx
    • KakersUK
      • Apr 2012
      I've been trying to get this to work for my company as it seems like a very handy tool. I think I may have it finally working, to a degree.. even though my PHP skills are terrible (working on it).
      Assuming this might help you guys out, I've uploaded what I've got to GitHub:
      GitHub is where people build software. More than 225 million people use GitHub to discover, fork, and contribute to over 800 million projects.
      • spaww
        • May 2009
        • 178
        #438
        SNMP-Builder for Zabbix 2.4
        Hi all,
        I release yesterday a new version of Zabbix-Extras (version 2.1). And with this version I send a new version of SNMP-Builder (with some adaptations for work in my tests and a easy install).
        The SNMP-Builder will be available in menu "Extras" Option "SNMP-Builder".
        For install: http://spinola.net.br/blog/?p=544#more-544
        Is for install with ZABBIX 2.4 only (I will try to put to work with 2.2 at same time too... but is not today).
        Adail Horst
        OCA/OCP - Oracle Application Server
        ZABBIX Certified Specialist
        http://www.spinola.net.br/blog (Blog sobre Zabbix e tecnologia)
        • PacMan
          • Sep 2014
          • 14
          #439
          Originally posted by spaww
          Hi all,
          After this installation, have error:
          "Function: get_oid_tree. Command: /snmptranslate -Ts -M /usr/share/zabbix/extras/snmp-builder/mibs -m DISMAN-SCRIPT-MIB. Error: 127"
          Does anybody know what's wrong?
          • spaww
            • May 2009
            • 178
            #440
            PacMan,
            You have Zabbix 2.4 ? And have SNMP-Tools package ?
            Adail Horst
            • Bill
              • Oct 2014
              SNMP Builder cant save to templates.
              I installed SMNP Builder on Zabbix 2.4 & Ubuntu 14.04.1 LTS
              Builder is operating and I can load the MIB that I want.
              The MIB tree appears and I can get values from the device.
              The /var/log/apache2 error.log fills up with messages as below
              Cannot adopt OID in OLD-CISCO-INTERFACES-MIB: locIfarpInPkts ::= { lifEntry 106 }
              Cannot adopt OID in OLD-CISCO-INTERFACES-MIB: locIfarpOutPkts ::= { lifEntry 107 }
              Cannot adopt OID in OLD-CISCO-INTERFACES-MIB: locIfarpInOctets ::= { lifEntry 108 }
              Cannot adopt OID in OLD-CISCO-INTERFACES-MIB: locIfarpOutOctets ::= { lifEntry 109 }
              I don't know if this is connected to the problem as this is not the mib I am using.
              I then try and save to the selected template and nothing happens.
              I don't see anything in Zabbix log.
              Please help.
              Bill
              • spaww
                • May 2009
                • 178
                #442
                Bill,
                I dont know. I dont change how SNMP-Builder works, I only make changes to work with Zabbix 2.4 and easy install. Someone with more experience with SNMP-Builder can help ?
                Please help.
                Bill
                Adail Horst
                • PacMan
                  • Sep 2014
                  • 14
                  #443
                  PacMan,
                  Yes, Zabbix 2.4/
                  Update OS and error was gone, but when I import MIB, it`s writing:
                  "Fatal error: Call to a member function useJQueryStyle() on a non-object in /usr/share/zabbix/include/html.inc.php on line 499"
                  Update:
                  If i copied MIB manual (by command line), all work.
                  • spaww
                    • May 2009
                    • 178
                    #444
                    Pacman,
                    Check permissions of directory... PHP need to write into folder.
                    Yes, Zabbix 2.4/
                    Update:
                    Adail Horst
                    • theocastelo
                      • Oct 2012
                      • 81
                      #445
                      Pacman,
                      I have the same problem Adail..
                      zabbix 2.4,
                      The folder have write permissions
                      • eagle
                        • Oct 2014
                        I have the following:
                        Centos 6.5
                        Zabbix 2.4
                        I have installed SNMP Builder following KakersUK instructions:
                        And same result: SNMP OID Tree is empty.
                        Which files need to be changed/edited to get this work?
                        Any help would be very appreciated.
                        • mmidgett
                          • Aug 2012
                          • 14
                          #447
                          Centos 6.5
                          Zabbix 2.4
                          Ive done the same with debian 7 and zabbix 2.2.6 and my tree is empty.
                          Can someone please show me what I have missed.
                          • Spoonman
                            • Aug 2013
                            • 45
                            #448
                            I have CentOS7 (64bit) and Zabbix 2.4.2
                            When I follow instructions to install snmpbuilder from KakersUK, I get a white homescreen, with no login etc....
                            Checked logfiles, and there is an error in line 28 from file "page_header.php".
                            I replaced this line with the original line 28 from my working setup, no luck.
                            (restarted HTTP, MySQL and zabbix-server services).
                            • mario5046
                              • Nov 2014
                              Installation snmp builder on debian
                              Can someone write step by step instruction how to install snmp builder on debian ?
                              I know that instruction how to install it on centos/ubuntu exist but I cannot find instruction how to do it on debian.
                              • spaww
                                • May 2009
                                • 178
                                #450
                                Mario,
                                Install Zabbix Extras and you will have SNMPBuilder together.
                                In portuguese:
                                Translated using google:
                                Is for Zabbix 2.4 ok ?
                                Adail Horst
