SNMP Builder for Zabbix
  • spaww
    • May 2009
    • 178
    #511
    Currently I are trining to update SNMP-Builder for work with ZBX 3... but have a lot of things to make to work
    Adail Horst
    OCA/OCP - Oracle Application Server
    ZABBIX Certified Specialist
    http://www.spinola.net.br/blog (Blog sobre Zabbix e tecnologia)
    • Gleb
      • Apr 2016
      Hi!
      I have imported mib file into snmp builder. I can see data in the OID data table, but there is nothing in Item list.
      There are no problems with pre-installed mibs. And mib file, which i have imported into zabbix, works well in PRTG.
      May be i do something wrong? I dont know - there are no errors in zabbix.
      • mosesjohann
        • Nov 2015
        v 2.4.8
        Hi there! Has anyone already tried install the 2.4.7 in a v2.4.8 zabbix with success?
        • registration_is_lame
          • Nov 2007
          • 148
          #514
          Originally posted by gelowe
          Does this work with zabbix 3.0? If not is anyone looking to update it so it will? seems like too good of a tool to not get added to the overall zabbix development.
          Doesn't work on zabbix 3.0.
          • Alfista
            • Mar 2017
            • 136
            #515
            Web converter...
            please can anyone help me and tell me where is the working web page for converting MIB files to Zabbix, while the WEB page on begining isn't workig anymore.
            I need to import many MIB files from many devices we have and I need some help to import it to Zabbix 3.2.
            Thanks.
            • syndeysider
              • Oct 2013
              • 115
              #516
              No one is actively maintaining this feature. You'll need some PHP skills to do this.
              • Alfista
                • Mar 2017
                • 136
                #517
                That's a bad information.
                Hope some one will find a time to work on it and finish it.
                Thanks.
                • toine7m
                  • Feb 2017
                  • 93
                  #518
                  Hope too :/
                  • syndeysider
                    • Oct 2013
                    • 115
                    #519
                    This works as a GUI alternative.
                    SNMP Template generator for Zabbix. Contribute to zabbix-tools/mib2zabbix development by creating an account on GitHub.
                    • Alfista
                      • Mar 2017
                      • 136
                      #520
                      https://github.com/cavaliercoder/mib2zabbix
                      Thanks I will try it :-)
                      • dave_it
                        • Aug 2017
                        Hi!
                        I've added SNMP Builder to my zabbix following the instruction: https://www.zabbix.com/forum/showthread.php?t=58062
                        Builder appeared in my zabbix but I can't see any OID Tree
                        • louis-m
                          • Nov 2013
                          • 70
                          #522
                          same here with 3.2. Screen is up but nothing being populated
                          • vlam
                            • Jun 2009
                            • 166
                            #523
                            Hi all, If we have different ports that is used for our SNMP so ranging from 4000 - 5000 is it possible to specify or change the port that the builder looks at when you are connecting to it
                            4 Zabbix Frontend Servers (Load balanced)
                            2 Zabbix App Servers (HA)
                            2 Zabbix Database Servers (HA)
                            18 Zabbix Proxy Servers (HA)
                            3897 Deployed Zabbix Agents
                            6161 Values per second
                            X-Layer Integration
                            Jaspersoft report Servers (HA)
                            • gospodin.horoshiy
                              • Sep 2008
                              • 272
                              #524
                              Hi, folks, have anyone tried this fork that is ported to Zabbix 3.2?
                              Zbx 2.0.4 on Debian and MYSQL5 on Ubuntu Server 64bit 8.04,
                              200+ Win Agents, 50+ Linux Agents, 150+ Network Devices
                              • ccandido
                                • May 2019
                                Hi all, I tried it ( https://github.com/mickvav/snmpbuilder ) with Zabbix 4.0 and it works!
