SNMP Builder for Zabbix
  • Hruiz_Arsnet
    • Oct 2019
    Originally posted by ccandido
    Hi all, I tried it ( https://github.com/mickvav/snmpbuilder ) with Zabbix 4.0 and it works!
    Hello there ccandido, did you used the same instructions that are on the readme on github? or did you modify anything to get it working. I want to install the builder too so i just want to know if you made any changes beforehand.
    Thanks.
    Regards.
    • jvalenzuela
      • Feb 2020
      • 12
      #527
      Thanks.
      Regards.
      Hello, Installed in 4.4 and works OK, following the page (https://github.com/mickvav/snmpbuilder) instructions
      regards
      • acognard
        • Apr 2020
        hi all,
        this is my first need, newbie with zabbix.
        i get the error below
        # echo $MIBDIRS
        /usr/share/snmp/mibs
        # ls -l /usr/share/snmp/mibs
        total 244
        -rw-r--r-- 1 root root 245492 mai    4  2013 Hestia-France-SNMP.MIB
        drwxr-xr-x 2 root root   4096 avril  6 12:58 old
        # snmptranslate -Ts -M /usr/share/zabbix/snmp_builder/mibs -m /usr/share/snmp/mibs
        Failed to parse MIB file /usr/share/snmp/mibs
        Begin of file
        Hestia-France-MIB DEFINITIONS ::= BEGIN
        IMPORTS
            enterprises, IpAddress, Counter, TimeTicks
                FROM RFC1155-SMI
            OBJECT-TYPE
                FROM  RFC-1212-MIB   -- SNMPv2-SMI
            DisplayString
                FROM RFC1213-MIB;
        -- Declaration du module IDENTITY. Indique quelques informations generales concernant l'entreprise
                hestiafranceidentity MODULE-IDENTITY
                    LAST-UPDATED "201004201030Z"               -- derniere mise a jour de la MIB 20/04/2010 10h30
                    ORGANIZATION
                        "Hestia-France SAS"                 -- noms de l'organisation responsable de cette MIB
                    CONTACT-INFO
        i googled many forum about this issue, but without any answer in my case.
        Hope someone can help me.
        • acognard
          • Apr 2020
          regards
          Hello all,
          on my zabbix server 4.4, it is ko
          "Cannot find module (SNMPv2-SMI): At line 6 in /usr/share/zabbix/snmp_builder/mibs/WWW-MIB mib Cannot find module (SNMPv2-SMI): At line 6 in /usr/share/zabbix/snmp_builder/mibs/WWW-MIB.mib"
          Any idea ?
          Tks in advance.
          • faruk@123
            • Sep 2020
            We are utilizing Zabbix 4.4 with this authority PostgreSQL format, be that as it may, when we eliminate an information base from our observed worker, the accompanying things are as yet checked:
            This fixes my concern with having the option to stack the HP mibs yet I'm not ready to really pull any information with any of the HP mibs. I additionally took a stab at stacking up Fortinet mibs for Fortigate firewalls and I'm not ready to get any information utilizing those either. When you attempted the HP mibs, did you really test them on any HP gadgets by some coincidence? For instance, in the event that I load up the HP-MEMPROC-MIB, I get nothing returned for anything HP explicit. Not certain in case I'm accomplishing something incorrectly but rather I've attempted each conceivable choice under the HP explicit areas. telecharger flstudio
            • krish123
              • Sep 2020
              Subsequent to playing with this over the previous week it's become progressively obvious that Zabbix outrageously needs an approach to relate an SNMP ifAlias with an interface. Prickly plants do this splendidly as of now and it would be a much-invited expansion to Zabbix geforce pour pc
              • eithor
                • May 2020
                • 50
                #532
                If you mean to only monitor interfaces matching a certain ifAlias, this is already possible in Zabbix with LLD and macros with regex. The standard Zabbix templates also have ifAlias shown in the latest data. Is there something else you had in mind?
