Another way to monitor Oracle
  • Filter
    when i use
    "UserParameter=pool_free_memery,/etc/zabbix/externalscripts/check_ora/check_ora_sendtrap.sh -i orcl -q pool_free_mem
    UserParameter=waitsqlnet,/etc/zabbix/externalscripts/check_ora/check_ora_sendtrap.sh -i orcl -q waits_sqlnet"
    write it in the zabbix_agentd.conf.
    I can get a number use ,"/etc/zabbix/externalscripts/check_ora/check_ora_sendtrap.sh -i orcl -q waits_sqlnet"
    in the terminal it has the answer.but when i use "pool_free_memery","waitsqlnet"as the key of the agent.but i can't get a Item key to monitor in the zabbix web.(I create oracle user .I only can open the oracle using oracle user.I can't open it with the root or zabbix user.how can i chanslate it .and every user can open the oracle).
    can you help me?
      If you have everything configure on "oracle" user you should be able to use zabbix_send under "oracle" user, try to check if path is correct (inside the script) and if you can use-it.
      Your issue seem caused by this kind of error.
      let me know
      btw It's holyday here so on next week I will not reply
      Andrea Dalle Vacche
      website:http://www.smartmarmot.com/
      e-mail:
      Author of:Mastering Zabbix Book - second edition
      Zabbix Network Monitoring Essentials
        let me know
        "try to check if path is correct (inside the script) and if you can use-it."
        what doed this mean?vi zabbix_send or change the zabbix_send to be root user?
          try to call zabbix_send inside your oracle user and see if enviroment's variable are right and everything work
          Try to see if you can call zabbix_send try to see if the specified path inside the scripts is right...
          just unix's admin stuff
          Andrea Dalle Vacche
          e-mail:
            How can i fix this problem?
            PHP Code:
            root@zab /e/z/externalscripts# ./check_ora.sh -i dbname
            ./check_ora.sh108: ./check_ora.shBad substitution
            root
            @zab /e/z/externalscripts# ./check_ora.sh -i dbname -s
            in log at that moment:
            PHP Code:
             WARN  Orabbix Error while executing ->pool_miscon database ->dbnameException received ORA-00942: table or view does not exist
             WARN  Orabbix
            Error while executing ->pool_sql_areaon database ->dbnameException received ORA-00942: table or view does not exist
            but that tables are exist:
            PHP Code:
            SQLSELECT TO_CHAR(ROUND(SUM(decode(pool,'shared pool',decode(name,'library cache',0,'dictionary cache',0,'free memory',0,'sql area',
            0,(bytes)/(1024*1024)),0)),2)) pool_misc
            FROM V$SGASTAT
            ;  2    3
            POOL_MISC
            1302,62
            PHP Code:
            SQLSELECT    TO_CHAR(ROUND(SUM(decode(pool,'shared pool',decode(name,'sql area',(bytes)/(1024*1024),0),0)),2)) pool_sql_area
            FROM V$SGASTAT
            ;  2
            POOL_SQL_AREA
              Orabbix - disabled items
              Hello, I'd like to ask if orabbix is querying also for disabled items in zabbix when they are queryies in query.props for this item.
              Thanks.
              Announcement
              No announcement yet.
