Another way to monitor Oracle
  • Filter
    Hi to everyone, i've wrote within a workmate a plugin for zabbix to monitor oracle instances.
    This script work on serverside and don't use zabbix send, but simply the zabbix server run some script and collect data from oracle instances.
    This plugin is server-centric because for me is more simple manage and upgrade a single application.
    The work that is done with zabora is simply great,and i've really apreciate! this is just another way to do more or less the same work.
    requirements:
    • a working sqlplus on zabbix server with configured tnsnames, and tnsping utility too. I've installed a complete client and not simply the instantclient, because tnsping is not included inside instant-client.
    • an user on every oracle instances
    installation steps
    create an user with this oracle script:
    CREATE USER ZABBIX
    IDENTIFIED BY <REPLACE WITH PASSWORD>
    DEFAULT TABLESPACE SYSTEM
    TEMPORARY TABLESPACE TEMP
    PROFILE DEFAULT
    ACCOUNT UNLOCK;
    -- 2 Roles for ZABBIX
    GRANT CONNECT TO ZABBIX;
    GRANT RESOURCE TO ZABBIX;
    ALTER USER ZABBIX DEFAULT ROLE ALL;
    -- 5 System Privileges for ZABBIX
    GRANT SELECT ANY TABLE TO ZABBIX;
    GRANT CREATE SESSION TO ZABBIX;
    GRANT SELECT ANY DICTIONARY TO ZABBIX;
    untar in /etc/zabbix/externalscripts check_ora.tar.gz
    write your credentials /username/password and instance etc..) inside
    /etc/zabbix/externalscripts/check_ora/credentials
    create items like on attachment check_ora_items.txt or import my template.
    then the last thing to do is add an host with the same name of SID.
    an you'll have a lot of graphs about performaces etc..
    in the picture you'll see some graphs
    See ya =)
    Dalle
    Andrea Dalle Vacche
    website:http://www.smartmarmot.com/
    e-mail:
    Author of:Mastering Zabbix Book - second edition
    Zabbix Network Monitoring Essentials
    just another screenshot =)
    Andrea Dalle Vacche
    e-mail:
      graph question
      Hi Dalle,
      thanks for the script.
      could you please explain how to get the hit ratio graph in kb/s - Mb/s just like in your example?
      don't matter just read the doc and think it solved... thanks
        Hi dalle!
        I don't understand the "write your credentials /username/password and instance etc..) inside
        /etc/zabbix/externalscripts/check_ora/credentials"
        Can you explaint it for me ?Thanks.
          Originally posted by dagun View Post
          Hi dalle!
          sure
          to connect to a database you need spacify username, password and instance name.
          e.g.
          sqlplus username/[email protected]
          databaseA.example.com is defined inside your tnsnames.ora e.g.
          tnsnames.ora:
          databaseA.example.com=
          (DESCRIPTION=
          (ADDRESS=
          (PROTOCOL=TCP)
          (HOST=192.168.0.1)
          (PORT=1521)
          (CONNECT_DATA=
          (SERVICE_NAME=databaseA)
          obviously on HOST you need spcify your ip address and on SERVICE_NAME your instance name.
          and so the credentials file is going to contain:
          databaseA;zabbix/[email protected]
          databaseA is the name of your monitored host and the name of database.
          I use the name of instance as zabbix host so you can have moultiple instance of oracle on the same server.
          for any trouble ask to me.
          see ya
          Dalle
          Andrea Dalle Vacche
          e-mail:
            Help me!
            When I use the oracle client to connect the oracle server , I get the error.
            My oracle server is on the window.the oracle service_nameracle
            My oracle client is on the linux.When I excute"sqlplus hrsoft/[email protected]"
            the fllow problem is:
            ORA-12504:TNS:listener was not given the SERVICE_NAME in CONNECT_DATA
            the"szg" is window's host name.ip:192.168.2.124
            My tnsnames.ora configuration is:
            szg=(DESCRIPTION)=
            (PROTOCOL=tcp)
            (HOST=192.168.2.124)
            (PORT=1521)
            (CONNECT_DATA=
            (SID=oracle)
            (GLOBAL_NAME=oracle)
            I will ask GLOBAL_NAME equal SERVICE_NAME?
            Thanks.
              Ok
              Hi dalle.
              I have resolve this problem.
              You do a good job.Thank you.
                New release
                Hi to everyone,
                i wanna pubblish a new release of check_ora, this version is slightly different from the previous because now zabbix server don't execute more the "chechk_ora.sh" but now check_ora.sh send trap to zabbix server so everything is asincronous and the server don't have more trouble with queue if you have a lot of database.
                In this release you'll need to schedule on crontab
                */5 * * * * /etc/zabbix/externalscripts/check_ora_cron.sh
                Then import the new template where every item is converted to "ZABBIX trapper"
                and extract the two files "check_ora_sendtrap.sh" ancd "check_ora_cron.sh" and place them on "/etc/zabbix/externalscripts"
                Everything is contained on the zip file in attach.
                See yaaa
                Dalle
                Andrea Dalle Vacche
                e-mail:
                  CFGFILE=&quot;/etc/zabbix/externalscripts/globalcfg&quot;
                  First of all, sorry for my pour english...
                  What I need in file CFGFILE="/etc/zabbix/externalscripts/globalcfg"?
                  This is a file or a directory?
                  When i execute the script ./check_ora_sendtrap.sh I have this:
                  ./check_ora_sendtrap.sh: line 46: source: /etc/zabbix/externalscripts/globalcfg: is a directory
                  ./check_ora_sendtrap.sh: line 184: /home/zabbix/.bash_profile: No such file or directory
                  Thansk for any help...
                    Don't worry about your english is not worse than mine
                    globalcfg is a configuration file imported by the script and contains
                    cat /etc/zabbix/externalscripts/globalcfg
                    ZBX_SENDER="/usr/local/sbin/zabbix_sender"
                    ZBX_SERVER="10.10.64.93"
                    ZBX_PORT="10051"
                    so you can write your file if is not present and put inside:
                    ZBX_SENDER="<LOCATION OF ZABBIX SEND>/zabbix_sender"
                    ZBX_SERVER="<IP_ZABBIX_SERVER>"
                    ZBX_PORT="<ZABBIX_PORT>"
                    See ya
                    Andrea Dalle Vacche
                    e-mail:
                      Thanks for help...
                      Again, sorry for my pour english...
                      I just have this now, think something is missing...
                      canes2:/etc/zabbix/externalscripts # ./check_ora_sendtrap.sh -i comrtst
                      Can you help me?
                      Thanks for any help!
                        Can you help me?
                        sure no ptoblem, i'm used to put there environment etc... on mine there is:
                        ##FROM HERE:
                        # .bash_profile
                        # Get the aliases and functions
                        if [ -f ~/.bashrc ]; then
                        . ~/.bashrc
                        fi
                        # User specific environment and startup programs
                        PATH=$PATH:$HOME/bin
                        ##UNTIL HERE IS STANDARD
                        ## FROM HERE THERE IS THE CONFIGURATION FOR SQLPLUS/ORACLE CLIENT
                        export ORACLE_BASE=/usr/local/oracle/10.2.0.4
                        export ORACLE_HOME=$ORACLE_BASE
                        export PATH=$PATH:$ORACLE_HOME/bin
                        export LD_LIBRARY_PATH=/lib/:/usr/lib:$ORACLE_BASE/lib
                        export TNS_ADMIN=$ORACLE_HOME/network/admin
                        export PATH
                        unset USERNAME
                        let me know if work
                        see ya
                        Andrea Dalle Vacche
                        e-mail:
                          I'm almo there... again...
                          Thanks for the help.
                          Now, if i execute this, it works!!! \o/
                          zabbix:/etc/zabbix/externalscripts # ./check_ora_sendtrap.sh -i comrtst -q pool_free_mem
                          110.03
                          Buuuut...
                          Some noob doubt's:
                          I have to run this scripts in the zabbix machine, or in all the machines I want to monitor?
                          When I run the file:
                          canes2:/etc/zabbix/externalscripts # ./check_ora_cron.sh
                          Sending failed. Use option -vv for more detailed output.
                          /usr/local/sbin/zabbix_sender -z 10.10.100.139 -p 10051 -s comrtst -k audit -o
                          If I don't put the -r parameter it works fine for me, but I don't get any information in the zabbix screen, just this:
                          Free memory
                          Processor load
                          Processor load15
                          Processor load5
                          Total memory
                          The -r parameter it's the parameter to send to the zabbix screen the information?
                          Thanks again!
                            Uouuu!!!
                            Man... I think I have some kind of problem.
                            Sending the sessions I have in database. They all doing the same thing.
                              try to execute
                              sh -x /etc/zabbix/externalscripts/check_ora_cron.sh
                              from a shell so you are going to see some extra information.
                              i'm sorry but this morning is an hell in office and i can't help you soon
                              Andrea Dalle Vacche
                              e-mail:
                              Announcement
                              No announcement yet.
