Another way to monitor Oracle
  • dalle
    • Mar 2009
    • 402
    #31
    zabbix check_ora 1.2 released
    n this release is included a new item and graph that is used to monitor archivelog production on a database.
    In particular i’m going to get an average value that is calculate on a slice of 10 minutes.
    So you can monitor your archivelog production, this is really useful if you have an Oracle DataGuard installation or simply to monitor the workload of transaction that are acting on youd database.
    Normally this value is really low, on mine database is something like 500 MB/hour but if an hig load is coming this value grown until 16-20GB/hour and is becoming dangerous.
    The trigger associated send a mail if this value is mode than 100MB/minute.
    downloadable here:
    or in attachment.
    more info here:
    on the following image there is the new check.
    Andrea Dalle Vacche
    website:http://www.smartmarmot.com/
    e-mail:
    Author of:Mastering Zabbix Book - second edition
    Zabbix Network Monitoring Essentials
    • alekmag
      • Feb 2010
      Monitoring Multiple Oracle Instances
      Hi for every one sorry for my pour english,
      I'm new working with Zabbix, I stay monitored two oracle server, with O.S. Linux Red Hat 4 and Oracle 9i Enterprise, but each one server have three Oracle Instances, I don't know how monitoring this instances with this method.
      As I understand it should create several new servers that have the names of each instance, I'm right?
      I appreciate any help I can offer, regards.
      • dalle
        • Mar 2009
        • 402
        #33
        it's easy to install , simply follow the instruction inside readme.txt or in this thread or on http://rootzone.wordpress.com/2009/1...og-in-generak/.
        Btw you need add for each instance an host, and apply to this host the "template oracle", and obviously your redhat server should be able to connect to each instance with a working sqlplus etc..
        Andrea Dalle Vacche
        e-mail:
        • thiagomz
          • Jan 2010
          • 74
          #34
          I am trying to import the template, but I am getting this error...
          Added new application Template_Oracle:Oracle
          Added new item Template_Oracle:ALERTLOG
          Added new item Template_Oracle:alertlog.warn
          Added new item Template_Oracle:archive
          Added new item Template_Oracle:audit
          Added new item Template_Oracle:cert.expire2
          Added new item Template_Oracle:connection
          Added new item Template_Oracle:dbblockgets
          Added new item Template_Oracle:dbconsistentgets
          Added new item Template_Oracle:dbhitratio
          Added new item Template_Oracle:dbphysicalread
          Added new item Template_Oracle:dbversion
          Added new item Template_Oracle:EXP
          Added new item Template_Oracle:EXPDP
          Added new item Template_Oracle:EXPDP_HISTORY
          Added new item Template_Oracle:EXP_HISTORY
          Added new item Template_Oracle:hitratio_body
          Added new item Template_Oracle:hitratio_sqlarea
          Added new item Template_Oracle:hitratio_table_proc
          Added new item Template_Oracle:hitratio_trigger
          Added new item Template_Oracle:lio_block_changes
          Added new item Template_Oracle:lio_consistent_read
          Added new item Template_Oracle:lio_current_read
          Added new item Template_Oracle:locks
          Added new item Template_Oracle:maxprocs
          Added new item Template_Oracle:maxsession
          Added new item Template_Oracle:miss_latch
          Added new item Template_Oracleerf_counter[\LogicalDisk(C\% Free Space]
          Added new item Template_Oracleerf_counter[\LogicalDisk(D\% Free Space]
          Added new item Template_Oracleerf_counter[\Paging File(_Total)\% Usage]
          Added new item Template_Oraclega
          Added new item Template_Oraclega_aggregate_target
          Added new item Template_Oraclehio_datafile_reads
          Added new item Template_Oraclehio_datafile_writes
          Added new item Template_Oraclehio_redo_writes
          Added new item Template_Oracleinhitratio_body
          Added new item Template_Oracleinhitratio_sqlarea
          Incorrect key format 'key_name[param1,param2,...]'
          Internal zabbix error
          No such monitored parameter (session) for host (Template_Oracle)
          Unknown ZABBIX internal error
          Zabbix 1.8.1
          Tkz All
          • thiagomz
            • Jan 2010
            • 74
            #35
            Just for documentation, I removed this item and all works.
            <item type="2" key="pinhitratio_table-proc" value_type="0">
            <description>Pin hit ratio - TABLE/PROCEDURE</description>
            <ipmi_sensor></ipmi_sensor>
            <delay>300</delay>
            <history>90</history>
            <trends>365</trends>
            <status>0</status>
            <units>%</units>
            <multiplier>0</multiplier>
            <delta>0</delta>
            <formula>1</formula>
            <lastlogsize>0</lastlogsize>
            <logtimefmt></logtimefmt>
            <delay_flex></delay_flex>
            <params>DSN=&lt;database source name&gt;\nuser=&lt;user name&gt;\npassword=&lt;password&gt;\nsql=&lt;query &gt;</params>
            <trapper_hosts></trapper_hosts>
            <snmp_community>public</snmp_community>
            <snmp_oid>interfaces.ifTable.ifEntry.ifInOctets. 1</snmp_oid>
            <snmp_port>161</snmp_port>
            <snmpv3_securityname></snmpv3_securityname>
            <snmpv3_securitylevel>0</snmpv3_securitylevel>
            <snmpv3_authpassphrase></snmpv3_authpassphrase>
            <snmpv3_privpassphrase></snmpv3_privpassphrase>
            <applications>
            <application>Oracle</application>
            </applications>
            </item>
            • dalle
              • Mar 2009
              • 402
              #36
              I'm sorry but i didn't have yet zabbix 1.8.1 probably is a trouble with this release, with 1.6.x the import of template don't cause any trouble, i'm sorry for the inconvenience but i can't try with your release now.
              Andrea Dalle Vacche
              e-mail:
              • thiagomz
                • Jan 2010
                • 74
                #37
                Dalle,
                Thank you for your plugin for oracle, it is simple and amazing !
                Could you explain me, how this triggers works ?
                {Template_Oracle:EXP_HISTORY.str(CORRECT)}=0
                {Template_Oracle:EXPDP_HISTORY.str(CORRECT)}=0
                how put this to work ?
                Thank you !
                thiagomz
                • dalle
                  • Mar 2009
                  • 402
                  #38
                  I'm really happy that you like mine work!!!
                  THANKS!!!
                  this trigger EXPDP, EXPDP_HISTORY are trigger that i use to monitor mine export on database.
                  I'm going to explain: i have another plugin, that when i have a few more of free time i'll publish, and this plugin simply keep monitored mine daily export datapump on oracle and History export. History export are export that runs on last day of each month. I use zabbix to keep monitored also rman/tsm backup whit another script, i'm sorry that this trigger and item are on template, are completely useless without the other plugin.
                  Thank you !
                  thiagomz
                  Andrea Dalle Vacche
                  e-mail:
                  • dalle
                    • Mar 2009
                    • 402
                    #39
                    released a new version 1.2.1
                    in this release there are some minor change in particular, i have correct the template and removed some query useless.
                    Andrea Dalle Vacche
                    e-mail:
                    • dalle
                      • Mar 2009
                      • 402
                      #40
                      check_ora 1.2.2 rleased
                      I’ve found a bug inside a check_ora_sendtrap.sh on line 58:
                      echo “ -s for sqlplus login connection and return time in second”
                      in particular there was an escape character and the line appear so:
                      without a correct termination, pleas download the new release 1.2.2 at
                      Download check_ora for free. This is a plugin to monitor oracle with zabbix. in order to run this plugin requires: 1) a working installation of sqlplus 2) an account on every database that you want monitor 3) zabbixzend
                      or in attach here
                      Andrea Dalle Vacche
                      e-mail:
                      • wolneykien
                        • Mar 2010
                        One other way: send Oracle values from a Java code
                        As far as I know Oracle can run Java classes and JDBC is very handy with Oracle. To turn a java class into a Zabbix agent a Jabbix Java library can be used. See "Jabbix" thread on this cookbook topic for more information.
                        • dalle
                          • Mar 2009
                          • 402
                          #42
                          please follow also this thread may be that is interesting
                          any kind of feedback will be appreciate
                          nice day to everyone!
                          Dalle
                          Andrea Dalle Vacche
                          e-mail:
                          • dalle
                            • Mar 2009
                            • 402
                            #43
                            Orabbix 0.5 released
                            I've released a new version of Orabbix.
                            actual improvements are:
                            1) Added retry on ZabbixSend items and values (max 10 times) , increased socket timeout to 30 sec.
                            2) Now exception are managed better and is less verbose i've revisited all loglevel to clean the software
                            Actually this daemon keep monitored 43 Oracle instances on mine production environment, with success
                            see ya
                            more info available:
                            downloadable here:
                            Download orabbix for free. Orabbix is an Oracle monitoring daemon. Actually is the smart and easy way to keep monitored Oracle and it's completely integrated with Zabbix.
                            Andrea Dalle Vacche
                            e-mail:
                            • dalle
                              • Mar 2009
                              • 402
                              #44
                              Orabbix Version 0.6.1
                              This is the same release i've just updated the template_oracle.xml inside Template directory.
                              I'm sorry but the old one was empty, please us this release instead Orabbix 0.6.
                              You ca download from here the new release
                              more info here:
                              see ya
                              Dalle
                              Andrea Dalle Vacche
                              e-mail:
                              • dalle
                                • Mar 2009
                                • 402
                                #45
                                new blog
                                Hi to every one, i've moved my blog here
                                nice day
                                Andrea Dalle Vacche
                                e-mail:
