Did you try this recipe? http://www.zabbix.com/forum/showpost...&postcount=238
SNMP Builder for Zabbix
When I access the file using vi or other text editors I get incorrect characters.
PHP Code:
+// SNMP Builder
+ 'S_SNMP_BUILDER' => 'Ã<98>üÿþÃ<80>Ã<82> SNMP MIB',
+ 'S_NO_HOST_ADDR' => 'Ã<9d>õ Ã<83>úð÷ðý ðôÃ<80>õÃ<81> Ã<83>÷ûð Ã<81>õÃ<82>ø',
+ 'S_INVALID_HOST_ADDR' => 'Ã<9d>õôþÿÃ<83>Ã<81>Ã<82>øüÃ<8b>ù ðôÃ<80>õÃ<81> Ã<83>÷ûð Ã<81>õÃ<82>ø',
+ 'S_OID_LIST_IS_NULL' => 'áÿøÃ<81>þú OID ÿÃ<83>Ã<81>Ã<82>',
+ 'S_OID_IS_NULL' => 'OID ÿÃ<83>Ã<81>Ã<82>',
+ 'S_INVALID_TYPE' => 'Ã<9d>õôþÿÃ<83>Ã<81>Ã<82>øüÃ<8b>ù Ã<82>øÿ',
+ 'S_OID_TREE' => 'Ã<94>õÃ<80>õòþ OID',
+ 'S_OID_DATA' => 'Ã<94>ðýýÃ<8b>õ OID',
+ 'S_CLICK_TO_FORCE_VIEW_AS_TABLE' => 'Ã<9f>Ã<80>øýÃ<83>ôøÃ<82>õûÃ<8c>ýþ ÿÃ<80>õôÃ<81>Ã<82>ðòøÃ<82>Ã<8c> ò òøôõ Ã<82>ðñûøÃ<86>Ã<8b>',
+ 'S_OID_NAME' => 'OID/Ã<98>üÃ<8f>',
+ 'S_DELTA' => 'Ã<94>õûÃ<8c>Ã<82>ð',
Ok... got this to work.
Got a problem when attempting to upload a MIB file though. I get:
Code:Command: cp -f /tmp/php200n4u /usr/share/snmp/mibs/v762b3.mib. Message: cp: cannot create regular file `/usr/share/snmp/mibs/v762b3.mib': Permission denied
Regards,
Sergey Syreskin
Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
Temporary out of Zabbix businessComment
It may be some JavaScript error. Are there any errors in the Apache log?Originally posted by MucaSire,
I have already done that?Regards,
Sergey Syreskin
H,
Upgraded to Zabbix 2.0 and installed SNMP builder script for v2.0. This is working apart from the fact that there are no images being displayed. No matter were I put the imgs folder.
In v2.0 were do the imgs go?Comment
Regards,
Sergey Syreskin
Sire, (and maybe some others)
Great job! Thanks!
I've made some chane to snmpbuilder to make a more unerstandable
description for zabbix item (only for interfaces: ifTable - ifDescr).
Now it looks like (for Cisco in my case):
You may see ifDescr as zabbix item description? which is much more useful to me than oid + ifindex (especially for a large number of interfaces)
The only difference is in snmp_builder.php (see attachment)
It may be simpy done for other tables or oids, but I can't figure what ones and what to use as description...Comment
Hi atimonin,Sire, (and maybe some others)
Great job! Thanks!
[ATTACH]4812[/ATTACH]
I also considered this feature, but think of a situation when ifDescr changes. Item description will no more represent the corresponding interface.Regards,
Sergey Syreskin
Yes, possible. Also possible that even ifIndex changes
(for ex. after conf change), but in all the case if I see ifDescr in item it's simplier to me to understand what's going on.
