SNMP Builder for Zabbix
  • Martins
    • May 2012
    • 25
    #271
    Hello.
    I'am trying to create zabbix for catching SNMP traps, so with SNMP builder I can import mib, and conwert it to item, then with this item filter trap and with trigger send to my e-mail readable notification? I'am right or I missing something?
    Thanks.
    • frlan
      • May 2012
      • 18
      #272
      I mean to zabbix directly. Its a bit fancy to add it to zabbix installation.
      • frlan
        • May 2012
        • 18
        #273
        BTW: Not sure I did something wrong with 2.0.0 but I'm getting this into php-log:
        [01-Jun-2012 13:29:29 UTC] PHP Fatal error: Using $this when not in object context in /var/www/zabbix/api/classes/CTemplate.php on line 348
        The screen is keeping "black"
        • Sc0rian
          • Jun 2011
          • 16
          #274
          thank you for such a awesome script.
          be good if someone commited the changes into the git repo.
          Awesome though, thanks
          • Martins
            • May 2012
            • 25
            #275
            Hello.
            I want to install snmp_builder, but can't find where can download it... In forum found that https://github.com/giapnguyen/snmpbuilder version is outdated. Where I can download version for Zabbix 2.0?
            Thanks.
            Sorry, found.
            • Martins
              • May 2012
              • 25
              #276
              Hello.
              I try to create item, but after pressing "save" nothing happens. I chose template to which save item, chose mib, and enter host's IP. No errors in apache log file. Using CentOS 6.2.
              • sire
                • Jul 2010
                • 210
                #277
                Hello Martins,
                Did you click at OID name (in OID Data table) for which you would like to create Zabbix item?
                Regards,
                Sergey Syreskin
                Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
                Temporary out of Zabbix business
                • troffasky
                  • Jul 2008
                  • 631
                  #278
                  How on earth has this managed to avoid being merged into mainline Zabbix?
                  • Sc0rian
                    • Jun 2011
                    • 16
                    #279
                    I second this
                    • sheen
                      • Apr 2009
                      • 24
                      #280
                      Originally posted by Sc0rian
                      I second this
                      +1
                      Since a long time, I'm merging snmp builder with each new version of Zabbix.
                      It should be merged in the mainline of Zabbix, this tool is really great.
                      • nelteren
                        • Sep 2008
                        • 16
                        #281
                        Hello.
                        Thanks.
                        Sorry, found.
                        Where did you found the 2.0 version ?
                        • Palmertree
                          • Sep 2005
                          • 746
                          #282
                          Look at thread #230. Took me a while to find it also. :-) Thank you Sire for the awesome patch.
                          • Sc0rian
                            • Jun 2011
                            • 16
                            #283
                            Originally posted by sire
                            Updated versions of my patches.
                            Added MIB file upload. In order to make it work, chown /usr/share/snmp/mibs (or wherever your MIBs are located) to the user id of your web server (usually it is apache, httpd, www-data). Also correct $mibs_dir in snmp_builder.php if needed.
                            If uploads fail, set upload_tmp_dir = /tmp variable in php.ini.
                            P.S. Do my patches work for you, are there any bugs/suggestions? I need your feedback.
                            Thank you for this. Works well.
                            • gridd
                              • Jul 2012
                              • 10
                              #284
                              Hello there!
                              Does anybody tell me where is latest version of snmp_builder.php for 1.8.5 Zabbix version? I would appreciate it very much.
                              Tnanks in advance, Alexey
                              I tried to use snmp_builder.php from #266 message of this tread, but got these errors in Information window
                              Use of undefined constant S_MIB - assumed 'S_MIB'[/usr/local/www/zabbix/snmp_builder.php:475]
                              Use of undefined constant S_SNMP_VERSION - assumed 'S_SNMP_VERSION'[/usr/local/www/zabbix/snmp_builder.php:494]
                              Use of undefined constant S_COMMUNITY - assumed 'S_COMMUNITY'[/usr/local/www/zabbix/snmp_builder.php:498]
                              Use of undefined constant S_MIB - assumed 'S_MIB'[/usr/local/www/zabbix/snmp_builder.php:501]
                              Use of undefined constant S_SNMP_BUILDER - assumed 'S_SNMP_BUILDER'[/usr/local/www/zabbix/snmp_builder.php:504]
                              Use of undefined constant S_OID_TREE - assumed 'S_OID_TREE'[/usr/local/www/zabbix/snmp_builder.php:524]
                              Use of undefined constant S_OID_DATA - assumed 'S_OID_DATA'[/usr/local/www/zabbix/snmp_builder.php:554]
                              Use of undefined constant S_CLICK_TO_FORCE_VIEW_AS_TABLE - assumed 'S_CLICK_TO_FORCE_VIEW_AS_TABLE'[/usr/local/www/zabbix/snmp_builder.php:554]
                              • gridd
                                • Jul 2012
                                • 10
                                #285
                                After installation of 1.8.12 patch, after clicking on 'SNMP Builder' I got in browser
                                HTTP 500 (Internal Server Error). SNMP Builder page cannot open.
                                Any suggestions?
