Another way to monitor Oracle
  • vjunior1981
    • Nov 2009
    • 10
    #16
    Don't worry...
    No problem man. I can wait. Sorry if I'm boring you.
    • Mich
      • Nov 2009
      Originally posted by vjunior1981
      When I run the file:
      canes2:/etc/zabbix/externalscripts # ./check_ora_cron.sh
      Sending failed. Use option -vv for more detailed output.
      /usr/local/sbin/zabbix_sender -z 10.10.100.139 -p 10051 -s comrtst -k audit -o
      If I don't put the -r parameter it works fine for me, but I don't get any information in the zabbix screen
      Hi, I have exactly the same problem.
      Zabbix sender help says:
      -o --value <Key value> Specify value of the key
      Your sendtrap script sends $MYMSG as key value:
      $ZBX_SENDER -z $ZBX_SERVER -p $ZBX_PORT -s $MYHOST -k $MYKEY -o "$MYMSG";
      And it is definied as third parameter given to sendtrap:
      MYMSG="$3"
      Correct me if I'm wrong, but I can't see third parameter in check_ora_cron.sh:
      ./check_ora_sendtrap.sh -i $host -q ${query%.sql} &
      Am I mistaken or you just forgot about sending query output?
      • dalle
        • Mar 2009
        • 402
        #18
        MYMSG="$3"
        the parameter $host is provided by the function :
        gethosts () {
        cd /etc/zabbix/externalscripts/check_ora
        cat credentials | grep -v '^#' | cut -d';' -f 1
        and in particular
        HOSTS=$(gethosts)
        so HOSTS contain a list of values, and inside for.. do cicle $host contain every values of $HOSTS
        for host in $HOSTS; do
        for query the method is the same:
        getqueries () {
        ls *.sql
        QUERIES=$(getqueries)
        in the begin of for.. do for every values of $query and of $host execute:
        ./check_ora_sendtrap.sh -r -i $host -q ${query%.sql} &
        if you run
        sh -x check_ora_cron.sh
        you will see the list of values contained inside HOSTS and the same for the values inside QUERIES
        for me is :
        HOSTS='DGDB0101
        ZBH02'
        QUERIES='audit.sql
        waits_sqlnet.sql'
        + cd /etc/zabbix/externalscripts
        + for host in '$HOSTS'
        + for query in '$QUERIES'
        + ./check_ora_sendtrap.sh -r -i DGDB0101 -q audit
        + sleep 1
        and in the end run:
        so if you want debug check_ora_sendtrap.sh :
        sh -x ./check_ora_sendtrap.sh -r -i DGDB0101 -q audit
        you will see the output of the script step by step.
        the last lines for me are:
        + /usr/local/sbin/zabbix_sender -z 10.11.77.93 -p 10051 -s DGDB0101 -k audit -o none
        Info from server: "Processed 1 Failed 0 Total 1 Seconds spent 0.001992"
        sent: 1; skipped: 0; total: 1
        this mean that the trap was sent correctly
        Andrea Dalle Vacche
        website:http://www.smartmarmot.com/
        e-mail:
        Author of:Mastering Zabbix Book - second edition
        Zabbix Network Monitoring Essentials
        • Mich
          • Nov 2009
          So, I was definitely mistaken
          Thank you for detailed explanation.
          Well, in my and vjunior1981's case it is not working. May be I will give a closer look to it later.
          Now I'm focusing on your first solution - via external scripts from server.
          Let me know if anyone will find something about this "Sending failed."
          • dalle
            • Mar 2009
            • 402
            #20
            no problem i'm happy that my explanation was clear
            if i can help you let me know
            Andrea Dalle Vacche
            e-mail:
            • dalle
              • Mar 2009
              • 402
              #21
              released on sourceforge
              Hi to everyone i've see that this project involve some people and so i've made a sourceforge project if someone want collaborate or has ideas or something please send me a feedback
              Download check_ora for free. This is a plugin to monitor oracle with zabbix. in order to run this plugin requires: 1) a working installation of sqlplus 2) an account on every database that you want monitor 3) zabbixzend
              Andrea Dalle Vacche
              e-mail:
              • rde-actinux
                • Nov 2009
                Thank you !
                I'm currently testing your programs with Zabbix 1.8 configured on RedHat cluster.
                In my case I'm focused on tablespace values and that does not work for me
                As you said I just need to configure my zabbix user on Oracle, configure my SQL+ client and check_ora.
                I put in crontab check_ora_cron.sh
                */5 * * * * /opt/zabbix/check_ora/check_ora_cron.sh > /opt/zabbix/tmp/zabbix_sender.log
                I can find in my output log:
                /opt/zabbix/bin/zabbix_sender -z 10.1.128.216 -p 10051 -s EMAUL -k tbl_space -o
                But when I try to read value in zabbix last values:
                Waits Controlfile I/O 16 Dec 2009 15:03:51 3 ms waits/s - Graph
                Tablespaces 16 Dec 2009 15:03:36 none - History
                SGA shared pool 16 Dec 2009 15:03:31 109.12 M - Graph
                Have you got specials tips to give me to get tablespaces values ?
                Thanks a lot again for your excellent job !
                • dalle
                  • Mar 2009
                  • 402
                  #23
                  i've got a looong looong time relationship with tablespace... and the resume is this: with autoextend =yes and when tablespace is composed from multiple datafile is completely an hell write a query that return a sorta of real value, i never finded a way.. sorry
                  Andrea Dalle Vacche
                  e-mail:
                  • rde-actinux
                    • Nov 2009
                    Tablespace monitoring
                    Ok, I worked a bit on my tablespace monitoring.
                    I wrote a request for getting my table space percent usage
                    ALTER SESSION SET NLS_NUMERIC_CHARACTERS=".,";
                    SELECT
                      a.tablespace_name AS name,
                      ROUND(100* b.bytes / a.bytes,1) AS percent_free
                    FROM
                     (SELECT tablespace_name, sum(bytes) bytes from SYS.DBA_DATA_FILES
                       GROUP BY tablespace_name) a,
                     (SELECT tablespace_name, sum(bytes) bytes from SYS.DBA_FREE_SPACE
                       GROUP BY tablespace_name) b
                    WHERE a.tablespace_name = b.tablespace_name;
                    On zabbix I can get that values (for example)
                    2009.Dec.17 11:57:20
                    SYSTEM                                 20.1
                    INDEX                                  66.7
                    USERS                                  19.1
                    SYSAUX                                 23.4
                    UNDOTBS1                               97.6
                    What I need is to set triggers on this results when value while raise 80. I can't do it actually.
                    I think I can do it passing tablespace name for each database but it will take to long to do (about 50 databases, with about 5 tablespace for each).
                    My question is easy; is it possible to parse this results in zabbix to extract and insert in Zabbix db only the name of the tablespace and % of free space ?
                    Thank you for your answer !
                    • dalle
                      • Mar 2009
                      • 402
                      #25
                      SELECT
                      FROM
                      For what i've seen is impossible parse this kind of output inside zabbix, is more easy do something like this:
                      select * from (
                      SELECT
                      FROM
                      where percent_free > 80
                      and simply do a trigger that become red when there is a sorta of output,
                      so you are going to see always green when you don't have nothing that has more than 80 % space used.
                      Consider that "system" tablespace is often fully used.
                      I hope this will help you.
                      Consider also this:
                      if USERS tblspace is made by 2 datafiles and ONE of this has autoextend this query return a wrong value, because don't consider autoextend and maxsize of datafiles. (this is what i mean for trouble with tablespaces query).
                      Andrea Dalle Vacche
                      e-mail:
                      • dalle
                        • Mar 2009
                        • 402
                        #26
                        Originally posted by gypeWaple
                        Hope your studies help you do better - for the Job you state you will get.
                        Whos paying your way Howie ?
                        Just adding up your comments in your posts - thats all, not really interested - but some things dont add up.
                        ok no more something of funny...
                        btw i really don't know how monitor tablespace inside zabbix a graphic visualization of used space etc.. should be useful but i don't know how do this, if you have any kind of idea let me know.
                        Andrea Dalle Vacche
                        e-mail:
                        • rde-actinux
                          • Nov 2009
                          Monitoring tablespaces
                          I partially solved my problem.
                          First of all, I created a request which admit one argument to get % free space on tablespace :
                          SELECT
                            /* for debug purpose :
                                a.tablespace_name AS name, */
                          FROM
                          /* name of tablespace in argument */
                          AND a.tablespace_name = '&1';
                          exit;
                          Then I wrote a small script to launch sql query with args.
                          #!/bin/sh
                          # Oracle environment variables
                          export PATH=$PATH:/home/oracle/bin:/home/oracle/oracle/product/10.2.0/db_1/bin
                          export ORACLE_HOME=/home/oracle/oracle/product/10.2.0/db_1
                          SQLPLUS=/home/oracle/oracle/product/10.2.0/db_1/bin/sqlplus
                          IP=
                          INSTANCE=
                          QUERY=
                          ARGS=
                          # Display help
                          printhelp() {
                          	echo "query_oracle.sh - an Oracle query for zabbix"
                          	echo "Usage: query_oracle.sh hostname instance query [parameters] [help]"
                          	echo "       ip          ip adress of oracle server"
                          	echo "       instance    to retrieve credentials from credentials file (must be the same with tnsnames.ora"
                          	echo "       query       execute a query and return just only the output"
                          	echo "       parameters  for extrat arguments"
                          execquery() {
                          	# `echo "Running $SQLPLUS -S $INSTANCE $QUERY $ARGS query " >> /opt/zabbix1/var/log/zabbix/zabbix_server.log`
                          	RES=$($SQLPLUS -S $INSTANCE $QUERY $ARGS)
                          	RET=$?
                          	if [ $RET -ne 0 ]
                          	then
                          		echo "Error while querying $INSTANCE"
                          	fi
                          	echo $RES
                          # testing args
                          if [ $# -lt 2 ]
                          then
                          	printhelp
                          	exit 1
                          fi
                          # better way to "shift"
                          IP=$1
                          INSTANCE=zabbix/zabbix@$2
                          QUERY=@/opt/zabbix1/etc/zabbix/externalscripts/$3
                          ARGS=$4 $5 $6 $7 $8 $9 # need improvment
                          execquery
                          I add group oracle to my zabbix account and add right read on my tnsnames.ora.
                          In zabbix, I add an Externel check using this script so I can get values for each Oracle instances.
                          What's wrong with it :
                          • I have to enter manually instance name (tnsnames.ora)
                          • I have to enter manually tablespaces name
                          An upgrade could be to monitor each database as zabbix host:
                          • Create each database in zabbix
                          • Modify tnsnames.ora to set instance name with database name in zabbix.
                          I'm quiet busy so in next step I'll try all that improvments.
                          I have no good solutions for tablespaces names
                          (Sorry for my english...)
                          • dalle
                            • Mar 2009
                            • 402
                            #28
                            i'm replying in late, sorry, i'm looking on your request.
                            If you don't want use tnsnames.ora there is a note wrote by asktom on his forum: http://asktom.oracle.com/pls/asktom/...45033135081903
                            i'm trying to find also a client that don't use tnsnames.ora this can be another way to solve your problem.
                            Sorry but i did not undestand the other two upgrade, actually i'm using already dbname as "host" in side zabbix.
                            Andrea Dalle Vacche
                            e-mail:
                            • dalle
                              • Mar 2009
                              • 402
                              #29
                              version 1.1 as been released
                              relase a minor version 1.1 more info here:
                              downloadable from here:
                              pratically i've just added an external configuration file, some comment anc cleaned a few the code.
                              This release is not jet tested on zabbix server 1.8.x because i didn't yet upgraded my servers.
                              For each trouble or question please ask to me.
                              see ya
                              Andrea Dalle Vacche
                              e-mail:
                              • dalle
                                • Mar 2009
                                • 402
                                #30
                                see ya
                                Andrea Dalle Vacche
                                e-mail:
